VirtualLarry
From a Newegg review:
This disturbs me, and reminds me of the 2nd-gen SandForce power bugs that would cause SSD corruption and hanging. Say it ain't so, that Samsung has the same sort of problems?
It's probably true, though, because I remember Samsung Magician would actively prevent your PC from entering a sleep state, probably to work around these bugs.
Should have picked up an Intel instead. I guess there's a reason why Intel SSDs carry a price premium. They work.
Richard J.
5/12/2015 7:04:51 PM
Tech Level: High
Ownership: 1 week to 1 month
3 out of 5 eggseasily damage by Sleep or Hibernate
This review is from: SAMSUNG 850 EVO MZ-75E500B/AM 2.5" 500GB SATA III 3-D Vertical Internal Solid State Drive (SSD)
Pros: OK fast read/write, low energy consumption. Con: Too easily damaged when installed in power conversing laptops. Read on.
Cons: I went through (i.e. damaged) TWO EVO 850 SSDs by installing Windows 8.1 on my laptop and the laptop would go into standby and sleep mode or I would shut down suddenly the BIOS reports missing boot drive etc on power up. Checked the BIOS, and its not listed. I'm using a new Clevo W740SU laptop to install from scratch. I call tech support, they say to disable all HD sleep setting in the power options. You can use Samsung software to do this (It actually creates a power setting called Samsung Power Save and I think disables all HD sleeping while the laptop is on. (Well I went ahead and set all the HD power setting manually after my 3rd attempt to successfully install Windows 8.1. So far so good.
