Samsung 840 or 840 Pro
Discussion in 'Memory and Storage' started by t0m3k51, Oct 29, 2012.
  1. jwilliams4200
    jwilliams4200 Senior member
    Apr 10, 2009
    532
    I wonder if they really are in stock, or if it is a glitch in their inventory system.
    If you do a newegg search for "Samsung 840 Pro SSD", in the list of all the models, all the 840 Pros show as out of stock. If you then click on individual models, except for the 256GB they all still show out of stock, but the 256GB model switches to in stock.
    http://www.newegg.com/Product/Produc...ro+SSD&x=0&y=0
    amazon has the 256GB 840 Pro in stock, but it says may take 1 or 2 days to process. They also have the 128GB in stock, but not at a good price.
    #26 jwilliams4200, Nov 6, 2012
  2. Puffnstuff
    Puffnstuff Diamond Member
    Mar 9, 2005
    6,667
    964
    It's already shipped and I've got a tracking number for it. If you want it you should buy it now as they won't last long.
  3. jwilliams4200
    Apr 10, 2009
    532
    Now it changed to showing the 256GB model in stock (all the others are out of stock). I just ordered one.
  4. m.alkhalel
    m.alkhalel Member
    Nov 6, 2012
    41
    You're forgetting 1 important thing, both 830 and 840 series have 3 years warranty while the 840 pro series has 5 years warranty.
  5. MrBighouse
    MrBighouse Junior Member
    Nov 6, 2012
    13
    I am considering these two drives as well. At first I was thinking get the latest one but from what I am reading here if I do heavy data copying to the drive I should go with the 830? I am a photojournalist and on a slow week I'll copy 5-10gigs of images to the drive and on a busy week it can get up to 50--100GB of data. Not all that data is kept obviously and then I delete half of that which makes even more writes to the drive. I have a older 2010 i7 macbook pro with intel 5 series serial ATA (3gigabyte link speed) so would the I even be able to reach the max speeds that the 840 has? I really appreciate any input on this.
  6. bradley
    bradley Diamond Member
    Jan 9, 2000
    3,664
    Neither. I would buy the 830, while you can. There will be no real world difference between the 830 and 840 Pro more than likely.
  7. MrBighouse
    Nov 6, 2012
    13
    By neither you are talking about the max speeds my macbook pro would be able to take in and out?
    The thing that gets me is the 512gb 830 is more expensive that the 840 (non pro)..
    http://ncix.com/products/index.php?minorcatid=1275#Samsung Memory & Storage
  8. MrBighouse
    Nov 6, 2012
    13
  9. MrBighouse
    Nov 6, 2012
    13
    By neither you mean both of the drives my macbook won't be able to handle the max speed? The thing that I don't get is the 830 512GB is more expensive that the 840 model.
  10. jwilliams4200
    Apr 10, 2009
    532
    The rated sequential write speeds for the models are:
    250GB 840: 250 MB/s
    256GB 830: 400 MB/s
    256GB 840 Pro: 520 MB/s
    If your computer only has SATA 3Gbps, then you will not see any speeds over about 270 MB/s. So you probably would not notice the difference between any of the three 256GB models.
    But if you might upgrade to a SATA 6Gbps machine in the future, keeping the same SSD, then the 840 Pro may be noticeably faster. It is also more expensive, of course.
  11. jwilliams4200
    Apr 10, 2009
    532
    The 840 uses the less expensive TLC flash.
    In terms of sequential write performance:
    840 Pro > 830 > 840
    In terms of endurance:
    830 > 840 Pro > 840 (probably, there is some guesswork here)
    In terms of warranty:
    840 Pro > 830 = 840
  12. MrBighouse
    Nov 6, 2012
    13
    Good point about upgrading but the way Apple is going now you can't upgrade drives as they are built in on the board which makes me think I will have this macbook for the rest of my life! haha :p
  13. jwilliams4200
    Apr 10, 2009
    532
    Or you might get a non-Mac someday! :sneaky:
  14. MrBighouse
    Nov 6, 2012
    13
    Exactly the way things are going I can see that happening. :)
  15. m.alkhalel
    m.alkhalel Member
    Nov 6, 2012
    41
    Yesterday Samsung announced that the 840 pro series will ship with Assassin's Creed 3 ! How cool is that!
  16. blackened23
    blackened23 Diamond Member
    Jul 26, 2011
    8,556
    Why would anyone get the 840, do you even lift?
  17. m.alkhalel
    m.alkhalel Member
    Nov 6, 2012
    41
    You forgot "bro" at the end lol
  18. kleinkinstein
    kleinkinstein Senior member
    Aug 16, 2012
    823
    Here are the exciting unreal world benches. Not sure why anyone would opt to spend $270 for a "performance" you'll never see, never feel, and never know when the 830 is $160.
  19. tweakboy
    tweakboy Diamond Member
    Jan 3, 2010
    9,518
    Forget benchmarks and latency.
    a 830 and a 840 you will not see difference IMO. period. I mean you already have 0ms access time , the rest is bulk transfer I mean ok maybe the 840 is newer product has better controller to make this Samsung generation SSD bullet proof. I believe in that. But I dont believe in a speed difference between these two SSDs. Heck you wouldnt know if I swapped a Crucial M4 , thats 0ms as well , same sh*T just samsung 512GB is over priced compared to M4. Soo I wanted a Samsung 830 but it was exaactly 700 dollars LOL to the door step. Im like wait a minute I cant spend this kind of money alto I understand the importance of it. Turns out to be the best upgrade Ive ever made in my life with PC's for over 25 years. I had to grab the 512GB version cuz I wanted everything on one SSD period, so I can do system backup image on my external 500GB. plus I can have as many games as I want right now 14 installed, all my data my DAW and I have 160GB free, feels good. Turns out I saw Crucial beat Samsung in a Windows 7 bootup test at toms hardware which is as legit as anand. 16.3 seconds,,, sammy 17.8 and Intel 18.5 ........ALso I love the firmware updates Im getting because this SSD just keeps on getting faster and faster,,,,,,, 010G seemed like a put a turbo boost on the drive,,,,, much quicker,,, I noticed certaini things certain apps, how long they took and saw how much quicker then came up with 010G ... Im a fan of firmware BIOS, beta, you name it gl
  20. Remobz
    Remobz Platinum Member
    Jun 9, 2005
    2,452
    This will be a Christmas gift to myself. I cannot wait to purchase my first SSD.
  21. zero koopa
    zero koopa Member
    Apr 21, 2008
    122
    For a 49.99 copy of Assassins Creed III and a larger E-Penis
  22. Coup27
    Coup27 Platinum Member
    Jul 17, 2010
    2,125
    I'm not so sure. The most relevant metric to system responsiveness is the 4k read. On an 830 this is ~25MB/sec. jwilliams4200 just posted benchmarks from his new 840 Pro and his 4k read is ~40MB/sec - that's a ~60% increase. I definitely think that would be noticeable and worth the money.
  23. Puffnstuff
    Mar 9, 2005
    6,667
    964
    I received my drive today so I'm happy. As for opting for a cheaper drive that is entirely up to you but I didn't.
    #48 Puffnstuff, Nov 8, 2012
  24. rgallant
    rgallant Golden Member
    Apr 14, 2007
    1,352
    just saying
    I think most people that own a 830 paid more than $160.00 for it.
    -so why begrudge someone buying something faster today for the same money .
    -the 830 seems slower in most case's to my g2 raid0 and I can't remember a time I spent real money on slower electronics to replace a item. $160.00 plus tax or $ 5.00 doesn't matter.
    the 840pro is much faster than my g2's ,so it should fit in with what I'm looking for ,which is one fast drive.
    -even when the 830 came out people paid more money for it's non noticeable ? speed over the cheaper products at the time. Why was that?
  25. katkah
    katkah Junior Member
    Nov 9, 2012
    9
    Did you get the game in your box? :confused: I wanted this drive for the encryption. It has 256 bit encryption capability whereas the 830 doesn't. Battery life for laptop too as someone else said.
