- Jun 30, 2004
- 16,304
- 1,877
- 126
This is still a mystery to me, and I thought maybe someone may know something I don't.
I've been upgrading my server. My server OS is WHS-2011 [based on Win 2008 R2].
I have installed two 4-port hardware SATA/RAID controllers in appropriate PCI-E slots (slots with more lanes than necessary), and the native Windows drivers are correctly installed: "Standard AHCI 1.0 ATA controller" is reported in Device Manager.
The system uses drive-pooling through StableBit, and I also installed StableBit scanner, which monitors the health of all disks in the system. Also, I have installed Samsung Magician, and it is fully functional except for inability to use RAPID_Mode, maybe because of the bandwidth limitations of the PCI-E 1.x slots used for the controllers. Everything else checks out: "Good," "Healthy" -- wonderful.
The only problem with the two Marvell-9230-based controllers: I either need to install a second LED light; install a drive light for every single drive; or live without the LED activity lights, since I have disabled the motherboard's onboard SATA controller.
Like other controller cards, the StarTech PEXSAT34RH units have a pair of LED pins for each SATA port, and a fifth pair labeled "ALL." So to avoid the trouble of installing seven more LEDs and wires in my case, I initially cabled the case's HDD LED to the "ALL" pins.
The flickering of the light suggests normal disk activity, but the light stays on . . . ALL . . the DAMN . . . . TIME!! There may not be much activity for the pooled HDDs -- one of which is on the same controller with the Sammy EVO boot-system SSD disk. Finally, I decided to remove the wires and connector from the "ALL" pins and locate the pins exclusive to the Samsung EVO SSD.
Behavior is the same!! The light is constantly on, even though it flickers to suggest normal disk activity. It has a default swap-file of 4GB. The monitoring software and Magician report nothing wrong.
But "IS THERE?" Is this "normal" for an SSD boot disk? This sort of activity-light behavior was not shown when the SSD was connected to the onboard nForce controller.
