CrazyChuckster
- Feb 14, 2002
- 702
- 0
- 76
Gosh SSDs are sorta not reliable after reading all this.
I have a sandforce ssd and I am getting a 1 second freeze about 2 minutes after bootup. It totally freezes, even the mouse. I suspect the drive but have not cared enough to look into... yet. However I also suspect it may be the logmein service colliding with aero. Since it only happens once I am not prepared to lay blame on the SSD.
I have two other OCZ drives that have rune fine for 2 years.
I have an 830 and I am using the latest RST driver. I have not had to do any LPM or any other "hack" to enure total stability. It worked out the box.Hey for those with the Samsung 830 how do you have it set up? Obviously ahci but are you using Intel rst driver or Microsofts drivers? (no one with the 830 had to do the lpm fix nor had to enable hot swap?)
