http://1saleaday.com/
Manufacturer: Samsung
Model: S27A550H
Features Include:
27 widescreen LED display
Breakthrough Picture Quality with LED Technology
Watch Full 1080p HD Video with HDMI
Samsung's LED technology reduces power consumption up to 40% - making their LED displays much more efficient than conventional LCD monitors
Your monitor will stay cool to the touch, even after a long day of hard work
Ultra Slim Design with Touch of Color Finish
A stand tail at the base of the monitor creates a hook that keeps cables in place and organized
Samsung's MagicAngle technology improves the off-angle viewing performance of the monitor so that it maintains superb image quality even if you are leaning back or lying down
With a built-in PIR (Pyrolectric Infrared Ray) sensor, the SA550 automatically detects movement within a specified area in front of the screen to automatically dim or power off, and then power back on or brighten once detecting a nearby viewer
The eco-light sensor adjusts your backlight to match the rooms ambience, soon in a dark room the screen will reduce brightness, but when sitting in a room with plenty of light, it will increase brightness
With a response time of 2ms, you can be sure that your monitor will perform perfectly, even in the fastest moving scenes
Packed with breathtaking 5,000,000:1 contrast ratio, the highest level currently available, the monitor ensures that blacks are at their absolute darkest and (with pristine whites) colours are at their brightest
16.7 million colors
1920 x 1080 maximum resolution
300 cd/m2 brightness
2ms response time
170 degree horizontal viewing angle
160 degree vertical viewing angle
VGA & HDMI interfaces
Adjustable tilt display
Green Compliance: EPEAT Gold
Dimensions with stand (Width x Height x Depth): 25.5 x 19 x 10.2"
Weight: 9.5 lbs.
Model: S27A550H
Features Include:
16.7 million colors
2ms response time
Weight: 9.5 lbs.
