- Nov 27, 2005
- 13,679
- 119
- 106
My LCD monitor has started to flicker like a strobe light when it turns on, and lasts for maybe 2 or 3 minutes until its fully working. Instead of just buying a new monitor, I decided I might try to fix it. Found this video which makes it seem doable
http://www.youtube.com/watch?v=cjjpmCcs8ho
The video says that the capacitors that are rounded on the top(which I guess are sort of "blown out"?) are the ones that have gone bad, and need to be replaced. How accurate is this? Is that all I have to do? If the monitor is still functioning somewhat, will I still be able to pick them out? And then I gotta learn to solder lol....
