Hi there... I really want to own a Samsung 215TW. In fact, I already bought one but had to return it, because I could not get it to recognize a DVI input from my laptop. A very weird situation... after having no luck at home, I actually went back to compUSA where I bought it, to check my laptop output (brand new alienware m5550). I was able to plug the DVI cable from my laptop into any of the other LCD flatpanels there, and to a model, each one showed my extended desktop (once I enabled it). But not the 215TW... I checked the floor model, too, and same deal.
So I called Samsung tech support (got to level 2) and described the problem. They said that I had to power cycle the monitor and then press the source button, with no input cables attached to the monitor. While it might take a few presses, ultimately this is supposed to kick the input over to digital from analog. So 215TW owners, I'd like you to do this with your 215tw right now if you can, and report back. I even called a second tier 2 support rep to confirm this, and they said the same thing. But all I ever got was the 'analog' box up in the top left, followed by the check analog cable screensaver box.
So, the store demo unit, the one I bought, and another one we opened at the store, ALL failed to behave as Samsung's tech support said they should. By their own admittance, a 215TW that did not ultimately kick over to the digital input under these circumstances would be defective. But I can't believe that three 215TWs are all bunk out of the box.
To summarize, my laptop DVI output is known good. In fact, the other weird thing is that my laptop is picking up the presence of the 215TW and allowing me to enable it! Just no sign that the 215TW is getting the signal. So what's going on here? Does samsung have a massive QC problem? Is this just a freak occurence?
Thanks in advance for anyone that tries the source search technique above.
David
David
