SAMOLED HD Plus in a Phone?
Discussion in 'Mobile Devices & Gadgets' started by poofyhairguy, Nov 17, 2012.
  1. Dari
    Dari Lifer
    Oct 25, 2002
    17,069
    4
    OLED lags SLCD in terms of power efficiency, color accuracy, high resolution, etc... Not sure why anyone would want it. I heard some people adjust their phones around the screen in order to take advantage of its advantages. That ultimately means black texts, black backgrounds, etc... How depressing.
  2. WelshBloke
    WelshBloke Lifer
    Jan 12, 2005
    20,754
    386
    I'm assuming that you mean white text on black backgrounds?
    White text on black backgrounds is fantastic for reading text only like eBooks. I do it whether I'm using OLED or not. It does look better on OLED than LCD though.
  3. Dari
    Dari Lifer
    Oct 25, 2002
    17,069
    4
    Is it better than black text on white background?
  4. TuxDave
    TuxDave Lifer
    Oct 8, 2002
    10,577
    I can't stand it.
    http://www.ironicsans.com/owmyeyes/
    My eyes strain drops when you flip it back to normal. I think this whole inverse color thing is a terrible fad and OLED just pushed it some more (better blacks and better battery life in that mode so now everyone wants to do it)
    #29 TuxDave, Nov 18, 2012
  5. WelshBloke
    WelshBloke Lifer
    Jan 12, 2005
    20,754
    386
    It's hardly a fad. Go open a cmd prompt in Windows and tell me what it looks like. :p
    I find it much more restful on a tablet or phone than having a big white light shining in my face. It's even better if you can set the type colour to off white as well.
  6. TuxDave
    TuxDave Lifer
    Oct 8, 2002
    10,577
    Oh sorry what decade am I in again? Command prompt? lol. Fads can be going old school you know. Or in this case going to inverted colors somehow make thinks look more high tech and old school becomes new school. Whatever suits you but it's clearly a fad in my book.
    When I do my work in Unix i override the colors to get black text on tan background. It helps my eyes a ton! If your eyes like it, go for it.
  7. WelshBloke
    WelshBloke Lifer
    Jan 12, 2005
    20,754
    386
    Use whatever suits you, but to describe something that has been done for decades and continues to be done, a fad, seems like a strange usage of the term.
    It's nothing to do with looking high tech or old school, I just don't like having a torch shone in my eyes when I'm reading.
  8. TuxDave
    TuxDave Lifer
    Oct 8, 2002
    10,577
    Coal power has been around for decades and it's still used. I would question why coal suddenly becomes super popular over alternatives, wouldn't you? I just look at the PC and internet today and I'm so thankful that the web is black text on white and not the archaic white text on black. (I'd even take white text on dark blue over black x100000. As that website mentioned earlier, I guess somehow it reduces the ghosting effect). I tried using the default white text on black and my eyes wanted to stab itself after 2 hours of work. You need SOME color on the blackground or else you get so many ghost images as your eyes pan across the screen.
  9. WelshBloke
    WelshBloke Lifer
    Jan 12, 2005
    20,754
    386
    Are you saying that using coal is a fad? I'm questioning now if we are having a fundamental difference in our definitions of the term fad.
    We are also not talking about using it on a 24 inch monitor, we were talking about phones.
    Again, use what you like, options are good. I was just pointing out to Dari why some people use dark themes. There's no need to try and convince others that only one way is the correct one.
  10. TuxDave
    TuxDave Lifer
    Oct 8, 2002
    10,577
    It's a (poor) attempt at an analogy to show that things that existed in the past, became less popular, and then became popular even though the initial problems have not been resolved, is a type of "old school" fad.
    I don't really care to convince you, I just posted some opposing opinion and some examples for people to use and determine what they want. I think people do a lot of things that I disagree with but there's no real benefit to me to convince all of them otherwise.
    I used the example post on my phone and it still causes strain on my eyes. So monitors, phones, tablets. I prefer non inverted colors because of that stupid ghosting effect.
  11. WelshBloke
    WelshBloke Lifer
    Jan 12, 2005
    20,754
    386
    It's all personal taste, why would you even begin to want to convince people to change? It's like trying to tell people they are using the wrong colour wallpaper on their phone.
    Seems a weird thing to get worked up about that people use a different background at times.
  12. dagamer34
    dagamer34 Platinum Member
    Aug 15, 2005
    2,592
    Samsung has made a 720p full-RGB Super AMOLED HD display in a Tizen developer phone earlier this year, they just didn't want to stick it into the GS3.
    I also think they are saving all of their abilities to increase PPI for resolution jumps rather than using an RGB stripe, because advertising your phone has 1080p is a lot sexier than advertising RGB stripe, which every LCD screen already has to begin with.
  13. TuxDave
    TuxDave Lifer
    Oct 8, 2002
    10,577
    I don't get worked up on it. Otherwise I would actually care to convince you otherwise. ;)
    So all the pentile nonsense made me go into a Verizon store to reevaluate my opinion. Is it visible still? Yeah, but only if you're looking for it and basically you have to look at text edge sharpness to spot it right away. It used to be so stupidly obvious on panning pictures but I have trouble seeing it there now. I probably would've been bugged by it....
    .... Except the sgs3 had something new to take the "stupidly obvious" crown. I opened the browser and nothing comes close to white. It's all a light blue! That's insane and enough for me to put it down.
    #38 TuxDave, Nov 18, 2012
  14. WelshBloke
    WelshBloke Lifer
    Jan 12, 2005
    20,754
    386
    Then don't buy one then, no ones trying to convince you.
    You seem to be having a problem with people liking different things.
    #39 WelshBloke, Nov 18, 2012
  15. TuxDave
    TuxDave Lifer
    Oct 8, 2002
    10,577
    I have no idea why you are getting agitated. I am probably the person who gives the least crap to people regarding purchases. If we are debating pre-purchase things, yeah i will jump in. Once a purchase is done, who cares. If it's not going to kill them I REALLY don't care.
    Calm down, it's just gadgets.
    #40 TuxDave, Nov 18, 2012
  16. ChronoReverse
    ChronoReverse Platinum Member
    Mar 4, 2004
    2,463
    Sounds to me you're the one getting worked up here.
    In any case, for paper, black on white is easier on the eyes but in terms of eyestrain on glowing screens white on black has the advantage.
    But with the _fad_ of making things that are digital have the appearance of real life things (like faux leather and real page flip animations), imitating paper is a nicety used ever since Windows.
  17. WelshBloke
    WelshBloke Lifer
    Jan 12, 2005
    20,754
    386
    I'm not agitated, the OP has already said he likes Samoled screens. Banging on about you not liking them seems like borderline trolling.
  18. TuxDave
    TuxDave Lifer
    Oct 8, 2002
    10,577
    He had concerns on pentile and I added my opinion on it. He said he liked over saturated colors and that was cool with me. Don't get so eager to label trolls.
    Admittedly the black on white thing was a big rathole but you can't say that I was 100% at fault for that tangent.
    #43 TuxDave, Nov 18, 2012
  19. TuxDave
    TuxDave Lifer
    Oct 8, 2002
    10,577
    I really hate the faux leather. Maybe if it was black leather but the brown leather drives me nuts.
  20. WelshBloke
    WelshBloke Lifer
    Jan 12, 2005
    20,754
    386
    OK then I'll tell you how to get rid of the blue hue in the internet app. :p
    Go to settings, power saving and untic background colour.
  21. s44
    s44 Diamond Member
    Oct 13, 2006
    9,339
    Oh yeah. Leaving this thing on makes it look INSANELY bad.
  22. MrX8503
    MrX8503 Diamond Member
    Oct 23, 2005
    4,531
    When I code, I use black backgrounds. Everything else I like white backgrounds. For e reading I like e-ink or sepia tone.
  23. TuxDave
    TuxDave Lifer
    Oct 8, 2002
    10,577
    Yeah! That's what I thought! The last time I saw something that bad was when the back light on the laptop screen was dying. I was thinking "is this a joke or something?"
    Thanks. Wish I knew this about a month ago. A friend asked me for advice regarding a new phone and the choice was iP5 and OneX. I was surprised and asked him why the SGS3 wasn't in the race for consideration and it was that very same blue hue that bothered him a lot. I can't blame him. I guess Samsung would have to come up with some method to mitigate the power efficiency when displaying white but as much as I like battery life, I would have to pass on this. You kind of wish at least the DEMO unit would have it off to showcase the phone at its best.
  24. WelshBloke
    WelshBloke Lifer
    Jan 12, 2005
    20,754
    386
    Well if the blue hue was there that means that they had all the power saving options on so they obviously not bothered about showing it off. Given the sales figures you can't really blame them, they are pretty much walking off the shelves on their own.
  25. poofyhairguy
    poofyhairguy Lifer
    Nov 20, 2005
    14,443
    276
    That and I really like how it washes out less in the sunlight.
    I would buy an OLED TV tomorrow if they made them in big enough sizes.
