Same WU times on a P3-950 and a Cel2-950 ??? what the hell???!! :(
The Magicman
527
Hi!
For those of you who've read my posting about which CPU to buy for S@H...
Today I've bought a P3-700 and oc'ed it to 952MHz (136MHz FSB, CAS3).
This baby does a WU in almost exactly the same time as my Cel667@950 (95MHz FSB, CAS2).
The only reason for this I can imagine is the CAS3 vs. CAS2 thingie ...
is there a faster client then v2.70GUI ???
Michael
Elite member
Nov 19, 1999
5,435
234
The CL 2.4 and the gui 2.04 are both faster. I think that the 2.76 client is a little better than 2.7. Also, one work unit doesn't tell the story, you need to try a couple to be sure (unless you're crunching the same WU for benchmarking).
CAS2 and CAS3 does make a difference.
Michael
The Magicman
527
2.04CLI is NOT faster then 2.70GUI!!!
..at least not unless 6h50min is faster then 4h30min
Where can I get v2.76GUI ?
blade47
1,353
Wu times vary greatly with v2.7 and up. So unless you ran the same wu then that's what the problem should be. The Via chipsets are slower than the BX as well so this could be the problem if your running a via. Cas does make a difference but the P3 should smoke the Celery2 due to the bus speed.
Magic Man v2.76 is slower than v2.7. It shouldn't be too much longer until v3.0 finally comes out and then we can get a better idea of which cpu's will be the most cost effective.
YGM.;)
The Magicman
527
The P3 is running on a BX chipset board (Abit BF6)
The Cel2 is running on a i810 Chipset baord (VERY bad memory performance)
Ken g6
Moderator
Dec 11, 1999
16,664
4,604
75
You don't want the 2.76 GUI. It's slower than the 2.4 CLi and the 2.04 GUI. :(
I started it on my system, a PII-400 which normally takes 8 +/- 0.5 hours to complete a WU with CLi 2.0. When I tried V2.70, it did some WUs in ~7hrs, and some in ~9. V2.76 did its first WU in 10.5hrs, and I'm now finishing up an 11.5hr WU just because it was half done.
If you really want it, though, an unofficial download site is here.
