- Apr 12, 2001
- 113
- 0
- 0
I have a motorola WR850G (802.11g) and just got a Netgear MR814 (802.11b). I set the MR814 to be a client of the WR850G. I have the WR814 routed via my LAN back to a LAN port on the WR850G. I am using static IPs for all of my connections to the WR850G. I have the MR814 @ 168.192.10.99 and if I connect via a ethernet cable to one if it's LAN ports it works fine so I believe I have set it up correctly to work with my network....now the real reason for doing this was to extend the range of my wireless network.
I have given the MR814 the same SSID as the WR850G and put on on channel 1 and the other on channel 11. They both have the same WEP 128bit key saved in their configuration for access. Should this be the case or do they need to be different?
What determines which network my laptop connects to? I apparently can only set up one network for each SSID on the laptop configuration software so does it just move automatically? Is it that one signal has to be weaker than the other before it moves? Is there a better way to do this?
Also I have settings for "any available network (access point preferred)", "access point (infrastructure) networks only" and "computer to computer (ad-hoc)" under my wireless's card's configuration. Which should I use? I assume one of the 1st two.
