- Oct 21, 2001
- 2,058
- 1
- 81
This is not a cooling question or a question about sensor accuracy, but a question about the possibility of one board actually causing the same cpu to run hotter or cooler that another board.
There are countless threads noting the difference in temp readings from one board or BIOS to another. I can understand some minor differences based on sensor calibration, type, and location on the board but my question is this:
Temp sensor variances aside, can one board actually cause the same cpu to run hotter or cooler than another board? Example: Board A shows a cpu temp of 48C but when the same setup is moved to board B the temp readings show a change of 12C. Sure, part of it is a calibration problem, but do some boards actually run the cpu hotter than others?
My ASUS board showed a temp of 51C and the identical setup in my Abit shows 37C. Sure there are sensor variances and I don't care about those as long as I know the difference, but I would almost swear that the Abit feels cooler when I give it the old "finger test." Even after a couple of hours of hard use the area around the socket and HS base are just slightly warmer than the rest of the board or cards (except for the AGP). Maybe it's just my imagination but it seems like the Abit board actually runs cooler. The case temps are also about 3C cooler now and I used the same parts and thermal compound. I would have thought the difference was all sensor error but maybe the board does make a difference. Hmmm.....
