Same audio issue with 2 brand new ASUS Maximus Formula boards
Discussion in 'Motherboards' started by SuperPuppy, Feb 13, 2013.
  1. birthdaymonkey
    birthdaymonkey Golden Member
    Oct 4, 2010
    1,175
    Well that pretty much rules out a software/driver problem. The only other possibility I can think of is some kind of weird conflict with the video card. If the third one still doesn't work, you could try testing with the onboard graphics.
  2. SuperPuppy
    SuperPuppy Junior Member
    Feb 13, 2013
    14
    Well, I installed the 3rd board and....
    Audio out of the rear green jack right out of the box.
    This means I either somehow damaged the board the exact same way while installing the board or I received two bad boards.
    If it is the later, I want the hundred hours of my life back that I spent troubleshooting this issue.
    Before I removed the board, I tested the HDMI port after I removed the graphic cards.
    It sent both the video and audio to the TV.
    I still only had audio out of the Headphone jack and not the rear green jack.
    Now I have a new problem, this board doesn't see my 2nd graphic card (yet) I removed and replaced the card without results, but I am done for the night.
    I do regret that I didn't bet bankster55 that he could resolve the sound issue in 10 minutes like he promised in his post.
    I do thank him and BirthdayMonkey for the assistance you both gave me.
  3. tweakboy
    tweakboy Diamond Member
    Jan 3, 2010
    9,518
    Cute looking BIOS tho... :(
  4. vailr
    vailr Diamond Member
    5,073
  5. SuperPuppy
    Feb 13, 2013
    14
    Last follow-up.
    I was able to get both my video cards working so now I have a 100% working system.
  6. birthdaymonkey
    Oct 4, 2010
    1,175
    Congrats!
  7. bankster55
    bankster55 Golden Member
    Mar 24, 2010
    1,124
    um, I didnt say I could fix your prob in 10 minutes, I said i could figure it out in 10 min if I was sitting there - merely by hooking up my portable oscilliscope to the output on a mini connector cable hooked into the green port and checking to see if there was any output at all. It either puts out signal or it doesnt.
    I also seriously doubt that 2 mobo had "bad" sound chips. There are so many things it could have been, like tightening the 9 mobo mounting screws too tight during first install and squeezing the delicate 6 layer mobo very tight in some place. Once done, breadboarding to test may not be of any use. I have also seen this happen with installing a stock Intel cooler (with mobo out of case) and a CM 212+
    But hey, a win is a win no matter how it happens. Just glad it wasnt involving the new non Pegatron manuf mobo. Kinda funny, been five months since changeover and have not yet seen one with a Oct or later date.
  8. SuperPuppy
    Feb 13, 2013
    14
    I don't think there there was much need for an oscilliscope, I could tell there was nothing coming out of the rear green jack because I never heard that slight "pop" when you plug in the speakers.
    Yeah, I should had known not to use my power drill with a phillips bit to drive in those nine screws.
    Actually, I used a precision screwdriver (the one that the top part doesn't spin) a size too small. (I still can't find the rest of the set)
    So the screwdriver popped out as soon as the screw stopped... I don't think I screwed it in too tight.
    I am reusing the Astek closed loop liquid cooling system, all I had to do was to buy a new retaining ring to fit the new board.
    The retaining ring uses thumbscrews that can only go so far into the board. You do not need any downward pressure to get the screws in (unlike the push pins) It was easy as pie for me to mount the heatsink on the CPU after I screwed in the board.
    I agree that it is very unlikely that ASUS would put out two boards with identical problems. I think that it even more unlikely that an experienced person damaged two boards the exact same way...
  9. bankster55
    Mar 24, 2010
    1,124
    As I mentioned in one of my earlier posts, I normally dont answer audio issue posts - its a losing proposition. However I felt PITY for you and answered anyways, despite my better judgement.
    And of course you now pay me back with your smarmy Mr. Know-It-All comments. Its become a contest to show that you are smarter than me. Now that you have your solution, I knew you were not going to just let it go, since your feelings appear hurt that I didnt recognize your infinite PC troubleshooting knowledge and expertise.
    So why dont you just get along with your life, and next time you have an issue, I'm sure you will be able to fix it by yourself eventually without posting here, since you are such an advanced user.
    And thank you for curing me of posting here in mobo forum - I only really come to AT nowadays for the Hot Deals forum.
  10. SuperPuppy
    Feb 13, 2013
    14
    Funny, I have been an ass to you in my posts to you since the tone you used in one of your earlier posts (2-20-2013 @11:39pm) and now you react to this?
    You threw out a couple of legit ideas in your last post on how I could have damaged the boards. I was just saying that those ideas couldn't happen because of...
    Maybe I did somehow damaged the first two boards, I was just eliminating the two ideas you threw out because they could not be true.
    If there really is a sound issue with some of those boards, ASUS and potential buyers should know.
    I troubleshooted the hell out of the two mobos and I thought I covered all the bases before I asked for help. You threw out a few good ideas that I did not think of and I tried every one of them. And some were a pain in the neck to do.
    And I thanked you repeatedly for your help.
    No, it is not a contest, I could never win if it was, I don't know how to use an oscilliscope..
    I don't like to be condescended, it was all about that...
    Reread what you wrote and maybe you will understand.
  11. jaqie
    jaqie Platinum Member
    Apr 6, 2008
    2,476
    for anyone finding this thread: anyone with intel HD audio especially that uses the realtek chip on the motherboard whether it admits to it or not... there is a very simple solution.
    installing the default realtek drivers direct from their site after uninstalling all other drivers
    when you install those specific drivers, the default behavior is for the realtek panel to pop up when it detects something plugged into any of the jacks back or front and asks you to assign that port to something. Intel azalia HD audio codec requires anything compliant with that standard to have reassignable audio ports and some drivers really munge this up. In realtek's reference drivers, you can even click the picture of the jacks and assign ports manually if and when it doesn't auto detect something inserted. It actually detects things by an impedance change on the chip and signals the software to pop up the assign dialog box for that port.
    This is extremely important for anyone who works with computers regularly to know and remember, I am honestly jaw agape that no one in this thread already seemed to know this. If the audio does not work after being assigned and using the test button in the speaker test tab with properly assigned realtek HD drivers, the chip or something else hardware on the motherboard is faulty, if you are using known good working speakers.
  12. whiskeyninja
    whiskeyninja Junior Member
    Jun 27, 2013
    Haha!
    I am going to be THAT guy.
    The guy that actually posts to the forum that explained and solved the issue he was having.
    I was having the exact same problem outlined in the thread, and was beginning to dread RMAing my Maximus V Formula, when I tried the advice quoted above. Works like a charm!
    Headphone and rear speaker jack work perfectly. I miss the snazzy interface for realtek that came with the install CD, but working audio is much preferred.
    Thanks for helping!
  13. snmnull
    snmnull Junior Member
    Dec 9, 2014
    My problem is same but in my case I am getting very low sound even on full settings, what should I do ? if it is a mobo issue or a software issue.
    Please suggest
    Intel Core i5 4440
    MSI H97M G43
    Realtek HD Audio
    Stereo speakers (with single jack)
