I've got a raid1 setup off an adaptec raid card with 2 hitachi hd's. I had troubles installing xp after creating the raid1 array. XP install couldn't find any storage devices. I called Adaptec tech support. They first said to do a low level format of the hd's and then try again. The adaptec card has an option to do a low level format of the hd's. I did that, created the array again, and still had the same XP install problem. I called adaptec tech support back again, and this time they said there was a known issue with the early hitachi sata drives, and that I should use a diiferent driver for the XP install. That seemed to work. XP installed, but now i'm having problems. The machine gives a message about contacting your hardware supplier, then locks up solid.
I'm wondering if the low level formatting I did may have caused this. Don't hd's come with a 'fault table' or something that marks the bad sectors and puts them out of use? Would a low level formatting destroy this table, putting the bad sectors back in play? Wish I knew more about hard drives. I generally avoid low level formatting, but since the tech rep said to do it, I did. Now I think that may be the problem. Any thoughts?
