- Dec 5, 2000
- 43,804
- 46
- 91
Every so often I need to go out into the factory area to work on a PC or something. When I'm out there, I'm required to wear either safety glasses or add some kind of side shields to my regular glasses.
I need to wear my regular glasses to see so I tend to just use the side shields that slip on over your frames. The ones we have here at work are garbage. They barely fit my frames. They were even scraping the plastic off my old glasses when I used them and now that I have a brand new pair, I'd rather not get them scraped up.
Basically, the side shields have a piece of plastic that goes around your frames and is held on/tight by a small screw. my frames barely fit through this opening, the screw and metal piece that it screws into always falls apart, and they're a huge PITA to put on and take off.
Is there a brand or type of safety glasses than will fit over top of a pair of regular glasses or is there a much better side shield attachment? I'd prefer to get a pair of safety glasses that fit over top of my regular glasses as that would be best.
I'd also like them to be inexpensive as I'll probably have to pay for them myself. I'll have to find out if they would reimburse me for it.
