I am considering upgrading my Core i5-7400 to an i7-7700k. All of the units I've seen appear not to come with a cooling solution. So, I'm wondering if I can reuse my current heatsink/fan. Does anyone know?
Thanks in advance!
Absolutely as long as the fan is in a working condition. Replacing a thermal paste will be necessary as advised earlier.I am considering upgrading my Core i5-7400 to an i7-7700k. All of the units I've seen appear not to come with a cooling solution. So, I'm wondering if I can reuse my current heatsink/fan. Does anyone know?
Thanks in advance!
Second the 212. However if you're willing to sacrifice 3 degrees celsius for something quieter and 1/2 the price, try the Chinese SnowmanYou would need to remove any thermal paste and apply a new layer. Also, that stock cooler isn't designed to handle the 7700k so it may throttle some and/or run hotter than you'd like. There are good options out there that only cost about $30, maybe $40. The 212 is a common budget recommendation.
550W would be safe, 650W is you're going to OC it a bit. This is assuming you have a high-performance GPU and a reliable brand as well.Is there a good likelihood that I'm going to have to upgrade my stock power supply?
I believe I have a 500W PSU. Do you think that will do the trick? I am using Intel integrated graphics, so no high-end video card.
Sent from my MI PAD 4 using Tapatalk
