Safe to put vodka in the freezer, right?
Howard
47,982
11
Originally posted by: Viper GTS
Yes, it will be fine.
A quick google search yields 80 proof as the cutoff point.
Viper GTS
Maximum or minimum? Minimum?
minendo
35,560
22
vodka would not freeze
actually most all hard liquors won't freeze only the girly drinks will
Yes they will, just not at the temperatures of a home freezer.
yukichigai
6,404
Vodka belongs in the freezer. Remember, it was made in Russia, where in the winter your spit will freeze before it hits the ground. If it can't handle a freezer then how in the hell did it come out of Russia?
Putting it in the freezer is also a good way to see if someone has been sneaking it and watering it down so you won't notice.
Judgement
3,815
Vodka is so much better straight out of the freezer, I wouldn't have it any other way
DanJ
3,509
Originally posted by: Bootprint
Originally posted by: FoBoT
how would it be dangerous? :confused:
If you try and drink it while it still supercooled it can cause problems to your stomach.
"supercooled"?
I doubt his freezer goes to sub-zero temperatures.
rudder
19,441
86
if it was real cold and you took a big swig of it, you could potentially get a severe case of brain freeze.
pcmodem
1,190
Vodka keeps well in the freezer.
I've got a bottle of Chopin vodka in the freezer at home right now.
Cheers, :beer:
PCM
