safe to hot-swap monitor?
snow patrol
8,377
Yes, I know this question has been asked many times and I really ourght to know the answer, but I just forgot and I want to make absolutely sure that I don't screw anything up. I've got another monitor arriving soon, but I need to keep my main rig on, but swap the monitor over to my server and then swap it back again.
ok, or not?
Cheers!!
fatbaby
Banned
May 7, 2001
6,427
well i had a scary incident with a monitor cable when my computer was OFF!
I unscrewed the monitor cable from one of my comps, and decided to plug it into comp #2.
When the monitor cable pins made contact with comp #2 (both comps and monitor are off), a giant spark appeared! It was fscking loud and bright too! it left a big burnt spot on my monitor cable...fortunately the cable and computer were unharmed so :D
SnapIT
Banned
Jul 8, 2002
4,355
Then the computer was attached to a grounded outlet and the monitor wasn't and the spark was the monitor unloading the static into the ground of the computer...
That would not hurt either, because it is basically a grounded lightning...
or it could just be that you forgot to plug in the monitor to the outlet before you plugged in the cable to the computer... pretty common...
WTT0001
1,510
I have one moniter and 2 systems and I swap it back and forth without any problems (all 3 on and running). Good luck.
WTT0001
Jan 9, 2002
5,232
Yep, because the pros behind the tech bench at Best Buy do it all the time!
They do, but more personally, 2 years ago I had a dorm room where our bunk bed butted up against the back of my roomie's desk. I would be sitting on the bottom bunk watching TV and occasionally unplug his monitor while he was working on it. He didn't suspect me for a few days. :D
"..WTF?!? I think my monitor just di... wait... WTF??!! now it's back on! dude, come fix this.."
Evadman
Administrator Emeritus<br>Elite Member
Feb 18, 2001
30,990
I swap monitors all the time too. no problems ( or killer sparks ) yet.
wampa
657
LOL
