Safe overclock voltage settings for GTX570?
killazys
I have the MSI Twin Frozr III. If I set all voltages to maximum in afterburner (+150mV core, +50mV mem, +30 aux) I can get 950/1900/2300 stable. But those voltages really worry me, and I haven't been able to find any literature on whether or not it's safe to max out GPU voltages (they're limited by... something, it seems).
Any input?
I personally would not max out the voltage. 900mhz would be a pretty good overclock, giving you better than gtx580 performance. You'd probably get a fairly significant drop in voltage if you backed off that last 50mhz.
