Safe max C2D temps?
VirtualLarry
56,585
10,225
E4400 on a Conroe865PE, running at 2.8Ghz at stock volts (list is 1.325, mobo reports as low as 1.25-1.3), temps are 61C running large FFTs, and 69C running small FFTs. Stock heatsink and paste. Are these temps bad?
Chaotic42
34,754
1,924
I'm running 71C with my E6600 with stock everything and I haven't had any problems. It's hot, but it's stable.
lopri
13,314
690
Every CPU is different when it comes to heat resistance, so it's ultimately up to your chip and your comfort. 69C is way over Intel's guideline, though. (I think they recommend 60C max for C2Ds)
MarcVenice
Moderator Emeritus <br>
Apr 2, 2007
5,664
69c is rather hot, usually people try to keep it at 60, a few bold ones try to stay below 65c. But the temperature sensors aren't all that reliable. You should consider throwing on a arctic freeer 7 pro or whatever for 15-20 bucks. It will take temps down quite a bit.
Elias824
1,100
man I must be crazy then, I dont like even like seeing 50c that much. I would definatly consider investing in a better cooler if you plan on keeping your computer for long
VirtualLarry
56,585
10,225
Intel C2D stepping list
Look at that, there is only one E4400 stepping entry. Click on that, and it shows:
Thermal Design Power: 65W
Thermal Specification: 61.4°C
Core Voltage: 1.162V-1.312V
So the question is, is that thermal spec measured on the outside of the case in the center, or do they mean the temps as measured by the DTS inside the core? Because if it's the former, then I'm probably ok, otherwise, not.
Another interesting thing is that the core voltage spec seems wrong. CoreTemp reports my default vcore to be 1.325v, which is above the range that Intel lists, although not an unusual vcore in general for C2D chips.
Accord99
2,259
172
61.4C is at Tcase, which is the top-center of the IHS so your temps are likely safe.
BonzaiDuck
16,611
2,018
See my remark in the current post with someone wanting help with his E6420.
As I said there, while the reports about OC'ing potential with the stock coolers of the C2D line are "good," I wouldn't bother even casual over-clocking without investing maybe half a Franklin-note in a good heatpipe cooler.
You're saving a lot more than that (until Intel prices come down this summer) by avoiding the top-of-the-line CPUs. Use some fraction of the money to get good cooling. Read the Anandtech review [published within the last few months] comparing some 15 or more coolers with the ThermalRight U-120 and U-120-Extreme.
