- Oct 30, 1999
- 11,815
- 104
- 106
Deal of the Day at Tiger. No rebates. Seems like a good price to me. I'm going to pick one up (TV in bedroom died.)
http://www.tigerdirect.com/applications...No=1048731&sku=M501-1012&CMP=ILC-FPM03
Sabrent SBT-TVFM PCI Capture Card
Capture video from your digital camcorder, watch TV, and listen to FM radio all from your PC with the Sabrent PCI capture card! Easily connect a DVD player, VCR or a game console to your PC with the S-Video and composite A/V jack. Sabrent PC to TV can also record, now you can watch TV on your monitor and record your favorite show at the same time!
Now, you can also Record TV & FM radio stations through our new software package available for download here.
Note: Uninstall older software before installing download, or install download rather than included CD Software.
Specifications
Easy install and User-friendly software.
Watch TV on your PC without any delay.
OSD: On Screen Display
Favorite channel list
TV channel Fine tune +/-0.25MHz
Max. resolution up to 640x480
Included software Teletext decoding
TV / Video Display
Video Window free scale
PCI 2.1 compliance with Plug & Play capabilities
Easy to use with Plug and Play
TV input
S-VHS input
Composite input
Audio input
Audio output via audio cable to sound card
FM signal input
A Closer Look
Features
Watch TV on PC
Built-in TV Tuner allows you to receive up to 125 channels on cable or TV air broadcasts.
Full Screen TV Display
User friendly software provides studio quality functionality.
Auto scan up to 125 TV channels
OSD function
Channel rename
Supports Composite / S-Video input or Composite Video Camera
Capture Rate: 30 frames per second
TV Frequency: CATV / VHF / UHF
Favorite TV channel editing
VBI supports Teletext
Support Teletext Mode
Remote control
FM Radio
Video Conferencing with Microsoft NetMeeting by adding a Video Camera
Minimum System Requirements: Windows 98SE/ME/2000/XP. 366MHz CPU or higher. 32MB RAM or above. VGA Card with at least 8MB memory. Available PCI slot. Analog TV signal source (Cable or antenna).
Specifications
TV / Video Display
TV input
S-VHS input
Composite input
Audio input
FM signal input
A Closer Look
Features
Watch TV on PC
OSD function
Channel rename
Remote control
FM Radio
