cytoSiN
Hey guys. I've got a question re: fan config in the s340 elite, which has two 140mm front fans, one 120mm rear fan, and one 140mm top fan.
I have a 280mm rad in front (Cryorig A80 with the included Cryorig 140 fans), with both fans as intake in push config through the rad. Yes, this moves warmer air into the case through the rad, but there's no other choice in this case. At least the whole front panel has an easily removable mesh filter.
The rear fan is a 120mm Noctua NF-F12 and it's exhausting through the 120mm rad on an EVGA 1080 FTW Hybrid.
So my question is what to do with the top fan. I have a Noctua NF-A14 up there, currently set to exhaust. I could flip is to use as intake (I'd add a mesh screen if I did that) to create (more?) positive pressure, but I'm not sure that's necessary? I've also got the 80mm fan on the A80 pump, which can point in any direction and be set to push or pull. It's not doing anything but helping to move the air in the chosen direction, but it could help by pushing air towards the rear or top exhaust, or if I flip the top fan to intake it could help force the intake air down to the GPU backplate.
Any help/comments appreciated. Thanks!
