S2000 tows a boat
Feb 10, 2000
30,029
67
It wouldn't be my first choice, but God knows in other parts of the world people routinely tow things with cars less powerful than an S2000, with manual transmissions. I still don't really see the point in doing this rather than just buying a cheap used pickup, but to each his own . . .
halik
25,696
dumbest thing I've ever seen
the first post there sums it up:
Just because you can do something doesn't necessarily mean you should do it.
StageLeft
70,150
Nifty but as mentioned in the thread I'd be concerned about its longevity. What's next, a honda fit towing a 30' yacht?
evident
12,130
749
if the dude could afford a S2k and a boat you would think he could afford a beater pickup to tow it.
zerocool84
36,041
472
Originally posted by: BW86
how can that thing tow anything with that little torque?
He swapped out the gearing for more torque. The gearing of an S2k was already geared for acceleration so I wonder how much worse his top-end is now.
LOUISSSSS
8,771
58
no the dumbest thing i've ever seen are 99% of americans that buy pick up trucks and never use the bed for more than some groceries and an occasional piece of wood
JulesMaximus
74,580
982
Or 4x4 SUVs and trucks simply because it snows a few times a year where they live.
Pacfanweb
13,158
59
That is an idiot, no doubt.
I saw someone at the lake a year or so ago with a small Acura, towing an 18ft boat. He was a dumbass, too.
overst33r
5,761
12
His previous top speed was a drag limited 155, but his gearing would allow for 165mph.
iirc he put in 4.77 gears, which would take his top speed down to 142mph. Besides forced induction, gears are the best bang for the buck mod on S2000s, especially the AP1s.
herm0016
8,516
1,128
i think i am going to dedicate getting an 85 trans am to you guys.
there is no way the non-existent frame will take that, what did he even connect the hitch to? the floor of the trunk?
ballmode
10,246
AP2 > Ap1
but anyways with S2000's really the best years to get are the even numbered ones since every 2 years it got an upgrade
2000 - intro
2002 - glass window, more interior goodies, suspension tweaks
2004 - 2.2L more torque but 8k redline, whole new suspension, stronger diff, bigger and wider wheels, more interior tweaks, burns less oil and with the new bumpers it is more aerodynamic and better mpg
2006 - Drive by wire, traction control, ecu is tunable with Hondata and various other programs, dynos report higher horsepower
2008 - more suspension tweaks, and the CR model was available
2010 - Dead, car won't be sold anymore, and no replacement :(
punjabiplaya
3,495
or a mid 20s white boy with chrome rims who hates black people but blasts rap music in his truck with a confederate flag on the back. God I love Texas...
BUTCH1
20,433
1,769
Originally posted by: brblx
i hope he's said his goodbyes to his transmission.
Not to mention the brakes on a small sports coupe are not going to do well at all trying to stop with a '20 foot boat in tow..
Pacfanweb
13,158
59
Hope I never see that dumb SOB behind me trying to stop that load with that little car.
BTW, if he ever had an accident with that setup, he'd have been sued to oblivion if there were any injuries. He would've have no leg to stand on at all.....that car, no matter what you do to it, is not rated to carry that load, and is a totally unsafe setup.
DivideBYZero
24,117
My parents tow a Caravan with a 140hp 2007 Civic. There are plenty of people posting complete nonsense in this thread. You don't need a four ton car with 450hp to tow. Some things, yes. Everything? No.
BUTCH1
20,433
1,769
This is true, but there are limitations for every vehicle. Usually the car maker will tell you in the owners manual what the car can safely tow. If the caravan falls within the guideline then tow away but I doubt it does, My 3,400lb 200Hp Malibu can only tow 1000 lbs according to my owners manual. It's transmission is only rated for 4,500lbs so there you go. Even if it had a 300HP engine with the same tranny you still max out at 1000lbs. Is it really worth it to risk blowing a transmission just to save some $$?, heck no, just rent a truck and tow with that, their much more robust drive trains are built for towing!..
radioouman
8,632
Virtually all American cars are now only "rated" to tow 1000 lbs. The Japanese and European cars typically have a more realistic tow spec still on their cars. I believe that the American car manufacturers were trying to force people into SUVs and trucks if they wanted to do anything other than put people into a car.
For example, the 1996-2001 Chrysler Sebring with the relatively wimpy 2.5 liter V6 and the four speed automatic transmission was rated for 2500 lbs. The 2002-2007 Sebring was rated for 1000 lbs even though it had the same transmission and a larger V6 engine. It was practically the same car with some body stiffening.
But, this guy is an idiot. Sure, most people that buy an S2000 are in their 20s and think that it will make them happy even though they will be broke. I don't doubt that this guy can't afford a pickup to pull his 1996 Bayliner to the water. This guy has very little towing experience of course and if he is ever caught in the rain trying to stop that boat, he will be screwed. If the trailer ever goes off the bottom of the ramp, he is screwed.
BUTCH1
20,433
1,769
That's interesting, never thought about it like that, maybe they were afraid of replacing tranny's with the longer warranty's offered nowadays or more likely as you suggest they are trying to force you to buy a truck to tow almost anything..
