s-video out while using SLI possible?
Lifted
5,748
I have 2 6800GT's in SLI and do not see the nview option in the nvidia control panel described on their site here
Enable TV out on nVidia card
Is it possible to have SLI enabled and use the s-video out for watching movies on my TV or do I have to disable SLI? I have the s-video attched to the same card as the monitor.
Lifted
5,748
Disbaled SLI in the driver options and the bios but now it wont even detect the TV.
Lifted
5,748
Has anyone gotten TV out working on an SLI setup, with either SLI enabled or disabled? I'm using the 6693 drivers and can't get it working at all. I've tried every possibility I can think of and nothing.
If you have gotten it to work, what card did you plug it into and what drivers are you using?
Thanks!
Lifted
5,748
surely someone is using SLI and can check to see if svideo out is working. please.
Lifted
5,748
somebody asked if I was trying to use the TV as a second monitor. I am, but only for 2d for movies and such, not for 3d. i just want to extend my desktop onto the TV/2nd display for the basic windows desktop, not 3d apps.
