http://www.reuters.com/article/2014/05/18/us-intel-chips-idUSBREA4H08P20140518
""I can guarantee for holiday, and not at the last second of holiday," Krzanich said in an interview. "Back to school - that's a tight one. Back to school you have to really have it on-shelf in July, August. That's going to be tough."
I don't consider October and certainly not December "tight".
1) Skylake's pull-in to Q2'15; 2 years after Broadwell, when you extrapolate Cannonlake is Q2'16
2) 14nm (and 10nm too) is projected to last exactly 2 years.
Intel doesn't see any major difficulties in the coming 10 years.
Huh? Intel's been using double patterning since 65nm. They chose to adopt double patterning before they adopted immersion lithography, which they used at 32nm.
Yes but: https://www.zauba.com/import-broadwell-hs-code.html
I'm not sure this proves anything except that engineering samples of Cherry Trail and Broadwell are flying around.
This basically sums up your whole post, you're milking Intel's 14nm yield issues to try to make your point. Everything suggests a release of 10nm in mid-2016, and you reply that they could have problems, like 14nm. Quite obvious, isn't it?
But those are just that: unforeseen problems. I don't see why I should take nonexistent problems into account.
I am also wondering how much of Intel's troubles with 14nm delays are due to its aggressive tightening of transistors and metal/poly pitch for this generation. It sure looks good on a chart when comparing vs TSMC, but they are trying to do two node jumps in one. Tough! They might just have shot themselves in the foot trying to bite too much. Maybe they should have been conservative and not tried to so aggressively outmatch TSMC on area.
Correct me if I'm wrong, but for some things you need double patterning, and for others Intel could still use single patterning in 22nm.
Intel adopted double patterning first for a number of reasons. First, you don't have to buy new equipment, unlike immersion litho. I think you still have to buy more scanners to mitigate the volume hit, but at that point dry scanners were "old equipment" and would be less expensive than fancy new immersion scanners. It's also relatively trivial for them to make new masks. You know there's something like 8 different configurations for Haswell alone?Seriously??
How can that be cost effective? Can anyone else confirm it?
Right. You don't need to do double patterning on metal layer 9, for instance.Correct me if I'm wrong, but for some things you need double patterning, and for others Intel could still use single patterning in 22nm.
Idontcare actually claims that TSMC is the one to thank for making immersion litho viable.
Burn J. Lin, TSMCs Vice President of Research and Development, has been awarded the 2013 IEEE Jun-ichi Nishizawa Medal for outstanding contributions to material and device science and technology for his invention of immersion lithography.
Lithography is just one of the steps involved in processing a wafer, and doubling the cost of lithography does not double the total cost of fabrication. You actually don't even "double" lithography costs by going to double patterning anyway, as you're only doing the parts that need it. These two reasons, primarily the first one, is why it still makes economic sense.
http://www.extremetech.com/computin...hography-technique-to-push-moores-law-to-20nmIntel adopted it for critical areas at 45nm, when the rest of the industry was pushing immersion lithography. Then, at 32nm, TSMC and GlobalFoundries began using some double patterning, while Intel went with immersion lithography.
http://semiaccurate.com/2014/07/11/intel-castrates-broadwell-gutting-performance/
may be this explains the F step? release a SKU to push products out while spending more time on optimization
Like civil war and ethnic cleansing between the Sunnis and Shias in Iraq was an unforeseen problem circa 2002. You should always take into account the known unknowns and unknown unknowns, as best as you can. Especially if you're predicting on a message board.
