Question Ryzen hidden Offset Voltage 0.05V Problem in BIOS & CPU & DRAM & SoC
KeMuケミュー
4
Ryzen Offset Voltage 0.05V Problem in BIOS & CPU & DRAM & SoC
(Requist : from Japan)
In BIOS of Ryzen.
Because the Offset voltage is being established 0.05 V without agreement,
I want BIOS to change Offset to 0.025V, not 0.05V.
I want you to change Offset to 0.025V, not 0.05V
Vcore Offset of Ryzen X numbler model is being established 0.10V without agreement.
Don't you stop to set Offset of 0.05V as 3 kinds of CPU, DRAM and SoC ?!!
" Decisive evidence "
DDR4 2666 CL16 1.21V
Micron A die 28nm (2015)
You must be able to use its voltage by DDR4 DRAM of 19nm and 22nm.
It's abnormal that it can't be used.
It's hidden, and the reason Offset voltage has been established.
Vcore and SoC
It has been specified by a report of the voltage.
Though it's so, the numerical value higher than its voltage can't be set and used.
When it's in case of Ryzen 1500X 3.5GHz.
1.1875V isn't put depending on a set any more in BIOS (20 ℃).
That's evidence for Offset 0.10V.
Thanks for reading!
A motherboard manufacturer is that I had everything my own way.
That won't be excuse.
The pressure of Intel is unrelated.
The voltage of the DRAM is that I have no relation in AMD and Intel.
It's a regulation violation that interference has even acted in DRAM.
Don' use this setting
Ryzen 1000 : Vcore 1.20V 3.5GHz 、 DRAM 1.25V 、 SoC 1.00V
Ryzen 2000 : Vcore 1.15V 3.8GHz , DRAM 1.25V , SoC 1.00V
Ryzen 3000 : Vcore 1.15V 3.8GHz , DRAM 1.25V , SoC 1.00V
Ryzen 4000 : Vcore 1.15V 3.8GHz , DRAM 1.25V . ScC 1.00V
Should use this setting
Ryzen 1000 : Vcore 1.25V 3.5GHz DRAM 1.30V DDR4 2933 SoC 1.05V
Ryzen 2000 : Vcore 1.20V 3.8GHz DRAM 1.30V DDR4 2933 SoC 1.05V
Ryzen 3000 : Vcore 1.20V 3.8GHz SoC 1.05V
Ryzen 4000 : Vcore 1.20V 3.8GHz SoC 1.05V
DrMrLordX
23,111
13,213
No offense, but that's a really difficult read. Sounds like you're having problems with voltage offset granularity on a specific motherboard? I've never had that problem on an x370 Taichi or x570 Aorus Master.
Reactions: Thunder 57
Hi-Fi Man
601
120
ごめんなさい、ちょっと難しいわかりました。
What software are you using to monitor voltages? try using HWinfo64.
