Discussion Ryzen 5600g and 5700g v. RX 550 and GT 1030.
DAPUNISHER
32,019
32,484
Spoilers: The APUs crush the old entry level dGPUs from AMD and Nvidia in most of the games tested in the video. Noteworthy that the 1030 and 550 were selling for $150-$200 last year.
God of War ran better on the dGPUs; memory bandwidth making the difference?
I think it is cool what a tiny APU can do. Looking forward to the next gen for desktop. Judging by the mobile results, a higher power allowance and overclocking, is going to yield some sweet budget gaming. And some cool tiny builds.
DAPUNISHER
32,019
32,484
Thanks, I haven't seen that channel before. Watched some of the other game test there, very impressive for a mobile setup.
Reactions: Leeea
Mopetar
8,489
7,736
In all fairness the 550 and 1030 are 5 year old GPUs at this point, so it's not that surprising that after ~2.5 full node advances that an APU can match their performance.
I'm pretty sure that the 5700G has the same number of CUs as a 550, so add in the generational performance gains and even with a restricted power envelope it should be able to compete with Polaris.
I'm personally still waiting for AMD to make something with a unified SLC that potentially gives their APUs 16+ MB of infinity cache. That'll do more to alleviate memory bottlenecks for 1080p gaming than anything else they could do.
DAPUNISHER
32,019
32,484
You're not wrong, but viewing things only through that technical lens? Well, it ruins a lot of the fun IMO.
Reactions: Leeea
GodisanAtheist
8,318
9,689
An infinity cache chiplet will be the holy grail of APU performance.
If AMD manages to make the cache a last level cache for the CPU as well when the GPU doesn't require it then all sorts of birds get killed with one stone.
aigomorla
21,067
3,574
The 5600G is a turtle once u setup to a real mid-low class dGpu.
The 1030 is not a gaming gpu.... i don't care what nvidia calls it, but i call it entry level productivity, not a GAMING dGPU.
A 1060 /w 6GB will slap a 5600G APU silly left right and up and down in all benchmarks across the board.
Even a 1050 slaps the 5600G.
I really do not recommend APU setup as a perm solution for a gaming PC unless your going be playing games which aren't gfx intensive, like banner saga, ammong us, counter strike, In the dark type game, where GPU prowess won't effect your PC much.
They should be a bandaid until crypto finally crashes, or until you can secure at least a reasonably priced 6600 series or even a 3050Ti.
Ive personally given up on AMD's APU, im a 5600X + dGPU or bust type person.
I just wont build with any APU only systems on a "Gaming' PC.
Its a disgrace to call it a gaming PC without a dGPU to begin with.
DAPUNISHER
32,019
32,484
How is beating that strawman going? I don't think anyone here was promoting anything you just went off about.
If you can't appreciate APUs, fine. But whatever you are ranting about is immaterial to this discussion. :p
Reactions: Leeea
aigomorla
21,067
3,574
Well to me it seemed like it was promoting the APU to be "acceptable" for gaming by comparing it with previous gen AMD cards.
Youtube has a lot of "5600G great for gaming" until you actually get one and try gaming on it.
I tried this route remember? I ended up with a BAD APU, then with the Good APU i ran into performance issues on half the games the niece wanted to play.
The APU is not great for gaming at all unless its a less then 2gb download @ steam.
I too fell for the youtube crowd and others saying it was an OK gaming alternative to a dGPU, when its not.
I think a mid low tier videocard should of been shown as a third reference, to show people just how underpowered it is for 1440p gaming.
Again... not raining down on the CPU... i just feel, they are not worth it, unless were building a straight up budget PC, which will have very little time with games, or any kind of graphic performance required situations.
I do not think the GPU on it should be a factor in your purchase, but more your wallet, in trying to save every last dollar possible because the 5600G alone will probably cost you HALF of what a 5800X + RX6600 / RX6500XT would cost you, but the later will probably net you triple the gaming performance easily if not into the 4x territory even @ 1440p.
I do not think its even a good stop gap until you can save for a GPU, because you lose out on that PCI-E 4.0, which no one cares to mention about, and i feel is quite important.
To me the chip has too many con's then yes, unless again, your looking at wallet, which then its one heck of a wallet pinching build, which will probably serve you well.
Edited: to make it read easily...
If you think im still beating the horse, then i apologize.
I just feel people should do more research on the CPU before getting it, or they will be forking a restocking fee like i did, for a 5600X.
Reactions: Leeea
DAPUNISHER
32,019
32,484
First off, no worries. You want to keep telling anyone that will listen about your bad experience?
Readers have to decide APUs pros and cons for themselves.
Your position is understandable. No one is happy after getting burned.
Of course, your experience is diametrically opposed to mine.
Also some of your statements are demonstrably inaccurate. In particular -
A 5600G costing half of what a 5800x RX 6 series combo cost? It sells NIB for $165 regularly, you'll pay $300+ for just the Ryzen 5800X NIB alone. And it is a bad example to begin with. It lacks any of the budgetary concerns and considerations for relatively low budget builds. Money dictates most of the choices, and a $300 CPUs never enter the picture.
Now, with the 5700g, I would agree with your contention. It needs to be gong in a small build, or destined for one, to pick it over the 5800X. Mine spends time in both roles.
Concerning the contention that the 5600G is a turtle with a dGPU? Fake news. First up, here are 2 of my systems compared -5700G v. 5800x both boosting a little past stock, tested with same card. Not giving up much GPU performance at all. Not getting merked in CPU performances either. The 5700G wins easy for iGPU gaming. ;)
Same goes for the 5600G. Here is mine with a 1080 versus the 100th ranked score in the database for a 5600x and GTX 1080. Dead even CPU performance thanks to the one click 4.7GHz all core overclock. My 1080 is stock though where the other is overclocked on both core and memory as the screenshot shows below.
Neither are world beaters, but calling either a turtle is pure hyperbole. I have played games with both using iGPU through the 3060ti and cards in between. They are great APUs. They don't hold back the 6600 or 6600XT in 3.0 8X. Both cards score exactly where they should for stock clocks in every 3DMark test I ran. Yeah, it is synthetic, but it serves the purpose of illustrating that these APUs are no slouches. I have compared games too. No way I can tell the difference between G or X with any of the GPUs I own.
All that out of the way, this thread was intended to demonstrate the capabilities of APU iGPU versus cards that have been selling for up to $200 for a couple of years now. That is fairly indisputable and pretty danged cool IMO,
Reactions: Leeea
VirtualLarry
56,585
10,225
Sounds a LOT like... trying to use a Pentium Gold 2C/4T Intel CPU for "gaming", even with a dGPU.
Which is a bit ironic, given the YT'ers "love" for things like that, but @DAPUNISHER , opposition, that they "just aren't good enough for a 'real' gaming experience", because of lack of cores or threads or whatnot, because they "stutter" regularly, or whatever the charge against them is. Which, ironically, could be applied to the GPU portion of APU gaming, I think, which @DAPUNISHER is a proponent of. Contradiction?
Edit: Holy hell, my posts read like a 'bot wrote them, tonight.
Reactions: Leeea and maddie
DAPUNISHER
32,019
32,484
First, What even is that I read? Also, I honestly feel like I am wasting my time. A bunch of financially established older folks with high end kit, playing at high res and settings. There is no common ground from a perception standpoint. For context: My kid has a hard time looking at me playing at 60 after playing at 165 for hours.
Where most disagreements come from, is due primarily to that subjectivity. For example: The less than 2GB download remark is laughably wrong from my perspective. Hence why there is no point in pursuing that line of debate. Nothing will come of it, as no one is wrong. Your subjective analysis is as valid as mine.
I will say, if you want to build a little HTPC or min-ITX that can't take a decent dGPU and expect to play all those horribly optimized AAA games from the last few years, without some real compromises to visuals and/or fps, you're gonna have a bad time.
Next: stating I am opposed to testing games without playing them, is a factual statement. But how you see that as a contradiction, because of my affection for IGP going back decades? Well you lost me there. One is a lack of enough testing. The other is deriving enjoyment from something while understanding its limitations. I can't see how those are comparable.
Not all get it wrong either. ETAPrime does a great job, and really shows what APUs can do. Of course, he knows the limits, and doesn't have unrealistic expectations. And is cool enough to show how bad something like Cyberpunk'd has to look to make it playable. Playable is subjective, and where discussions get spicy. Anyone that checks my post history, knows I don't do debates, or flame wars. I don't mind if I am wrong, or admitting it. I ain't looking to be that rare individual that wins a debate or argument on the interwebz. I communicate what I want to convey, then I'm done. Ergo, this will be my last reply to any of this contentiousness.
I have had warm feels for IGP for decades. I think it is one of the more interesting areas of PC parts. Something about being able to game without a discreet vid card has always felt more like the future to me, than any other PC hardware. I like that feeling.
Concluding opinions and info: I play games appropriate to the APU. Because I go in knowing full well the limitations. Limitations that are less than the 2 dGPUs that inspired the thread. :p Games like MC collection, Fallout series, Half Life series, Batman series, older Assassin's Creed games, older Call of Duty, Dirt series, Dirt Rally series, Forza series, GTA series, Mad Max, Just Cause 1-3, Tomb Raider 2013 (Haven't tried the others yet), Sleeping Dogs, Home Front, Warhammer 40K space marines, my entire GOG library, some OG Xbox emulation e.g. Destroy all Humans; The list goes on. I play the majority of those listed and others, at 1080p higher settings. A few more demanding at 1080p custom. A couple might even mean low settings or dropping to 900p and whatev settings.
As I have mentioned before, I have systems from APU to a mid tier gamer 5800x and 3060ti. I play games appropriate to each system. Cyberpunk'd is best on the 3060ti, you get the point. So when the game runs great on a power sipping APU, heck yeah I will play it there.
19,175
If only Intel had decent iGPUs, game developers would spend more time on making their games look prettier on low end hardware and AMD APUs would benefit greatly from the optimization effort too. As things are, they just can't be bothered because they don't believe anyone would seriously game on an APU.
I hate dGPUs exceeding 300W power draw. Hopefully after 2025, both Intel and AMD will have decent enough iGPUs that game developers will make the effort to make at least 1080p Ultra setting work great on them. It will only increase their sales because everyone isn't willing to get a dGPU but if the game runs on their iGPU just fine, they can just get into the game whenever they feel like just because they can. Essentially zero price of admission to be a gamer, rather than spending something like $200 or so for a low end dGPU.
Reactions: Leeea
19,175
Intel could certainly upset Microsoft and Sony if they released a console level APU with integrated 16GB GDDR6 to the general public. OK performance in applications but great performance for games. Release a newer gen APU every five years and console market would shrink drastically. Why buy a console when you can build your own, customizing it with off the shelf components like cheaper and faster NVMe SSDs, better cooling and possibly even overclocking?
AMD is prohibited from doing that due to their console agreements so Intel's got an opportunity to do some damage. Better yet, how about segmented line-up of i3, i5, i7 and i9 APUs?
DAPUNISHER
32,019
32,484
The strategy is obvious. Live 4-5 yrs in the past and you can game on APUs forever moving forward. Forget the BS pressures from the loud mobs. Did we not enjoy games of yesteryear?
I have more hours in Fallout games, Skyrim, and Mad Max alone, than probably everything that has come out in the last 3yrs combined. All of them look and play great on my 5700G.
That said, I agree with the criticism that the 5600g and 5700g make no sense as placeholders now that prices are reasonable, and there are new entry level dGPUs under $200 that are much faster. Pair them with a 12100 for a great low budget build. But until the new APUs hit, there is simply nothing better for a tiny gamer and emulator.
I have seen some cool 12th gen ones, but the graphics and drivers are not yet on the same level, and the prices are higher. Though when/if SFF Tiger Lake boxes get cheaper I may get one of those to mess with. I swear I read somewhere Intel has picked it up on releasing new drivers. Or was I dreaming? :p
Reactions: Tlh97 and Leeea
Tup3x
1,275
1,406
Arrow Lake with the rumoured 320 EU GPU would be pretty nice - assuming that it has enough memory bandwidth. I'd like to see manufacturers solve that in some way for high performance APUs.
Leeea
3,799
5,566
I feel compelled to point out that for Consoles, 30 fps is the normal.
It would seem that DaPunisher is pulling 60 fps with an iGPU, and considers that an inferior experience.
That is an interesting thought. But what is PCIe 4 important for?
Certainly not GPUs, as any 16 channel card will have no desirable difference in performance between PCIe-3 and 4. Yes, there are some 4 channel budget units from AMD that need PCIe 4, but those are the exception rather then the rule.
The same applies SSDs. PCIe-3 units are not desirably slower then PCI-4. Yes, on the graph it is slower, but in perception? I doubt anyone can tell.
I think the real flaw with PCIe-3 is knowing about it. That is the real reason I wanted PCIe-4, I knew it existed, it was 2x faster, and I wanted it. Knowing I was missing out on something even though I also know it really does not matter.
I feel that is the flaw with the 5600g and the 5700g. After you eventually do add in the GPU, at the end of it all you will always know you missed out on a bit of clock speed, a bit of PCIe lane speed, and that if you had spent the same amount of money on a 5600x + GPU from the get go it all would be just slightly better. Insignificantly better, but in my mind at least, better none the less.
All that said, iGPUs do have their moments even in dGPU systems. Especially if said dGPU was used and starts acting up. Or if that used dGPU was a Vega series card with their substandard multimonitor support and you would like another monitor.
