- Apr 26, 2011
- 428
- 151
- 116
So last night I ran memtest on my 4x8gb sticks of gskill ram (4-3200C14Q-32GVK) . I had the memory running at xmp settings (3200mhz) at 1.35v. I woke up this morning to 675 errors in memtest. Before I left for work this morning I lowered the memory speed to 2933mhz with the same timings as xmp and voltage and began memtest testing again.
I'm pretty sure the ram is good as I have not ran into memtest errors in the past with using all 4 sticks on Intel systems. Is it possible I'm running into motherboard and/or cpu limitations with trying to run 4 sticks of ram and that's what's causing the memory errors? If I get home from work today and have no errors testing at 2933mhz, I am thinking of stepping down to 2x8gb and running the memory at faster speeds than what I can with 4 sticks. I don't need 32gb of ram and if it's going to result in me not being able to crank up the memory speed I'm willing to step down to 2 sticks for a total of 16GB. This is dual rank Samsung b-die. In my old Intel system I had it running at 3600mhz no problems
