- Apr 20, 2009
- 3,793
- 1
- 81
Just look for someone who may have experience in this sort of thing. I've done some digging and it seems I need POR15 fuel tank sealer. Just not sure of the quantity that would be necessary for a 7 or so gallon tank on an Allis Chalmers WD45.
Also, it seems I'll need to do some rust removal before applying the product. I've read methods that involve vinegar (weak acid), muriatic acid, toilet bowl cleaner, etc. I am actually leaning towards electrolysis, but I am a bit leery when it involves a gas tank. In addition to electrolysis, I may throw some nuts and bolts into the tank and shake it about to clear any large debris.
Then seal with POR15 fuel tank sealer, but I have no idea how much to get. Seems to be some pretty expensive stuff, with a quart going for $40 on Amazon.
As it is, the tank is drained, but I still need to remove it. Anyone done something similar? Any good suggestions? I'd like this to be as inexpensive as possible.
