Rust in toilet tank, replace?
pete6032
8,044
3,503
I have a 15-year old toilet whose bowl gets dirty very quickly because there is rust build up in the tank. I have taken the tank off and looked in it and the rust build up is pretty bad. What is the best thing to do, replace the tank or try and clean it out? If I clean it out how should I clean it? Would getting one of those clorox pills help?
herm0016
8,515
1,128
take it apart and clean, replace the tank bolts with brass or stainless, and you may as well throw in a new valve. should work like or better than new. no need to replace the whole tank.
Reactions: shortylickens
Scarpozzi
26,391
1,780
It's a porcelain toilet, right?
Metal screws come in a few varieties...sounds like they used Zinc-coated or low-quality stainless. It's possible that the chlorine in your water has actually caused the bolts to rust faster too since chlorine is caustic to steel.
You can get replacement tank bolts in a kit with new rubber gaskets. A new toilet costs $100-150 and up. If you're ok with the toilet, new hardware for the tank should be pretty cheap, not more than $10 and takes less time to install because you don't have to deal with your toilet flange and all that. Either way, you're going to deal with toilet water when you mess with it.
Here's a video on Korky replacement parts (since I don't know what brand of toilet/tank you have). Most big-box stores will have these kinds of parts and people there can help you. Just figure out how many bolts are in your tank, (2-4) and what brand it is. The bolts are used to compress a rubber gasket between the tank and the bowl to make that connection water-tight, but you don't want to overtighten the bolts.
rsutoratosu
2,716
4
I had the same issue, when I replaced the flat, I remove everything and clean it out, changed hardware, ete, few weeks later, the tank looked like i never cleaned it... rust spots building up.. I just didn't bother at that point
