running Xbox 360 on VGA... best monitor?
msi1337
7,834
if I want to run xbox 360 to my computer monitor..what size lcd would be best to view the Xbox 360 in optimal resolution. I currently have a 17" Dell LCD... is this sufficient, or should I get something bigger/better?
IF I upgrade here is what I need:
1) something to run Xbox 360 well
2) something with DVI & VGA
3) something in either 19/20/20 wide
thoughts...what about that new dell 20 inch widescreen for $289?
ForumMaster
7,792
sounds good. are you sure you want a computer monitor though? or is it going to be for your computer as well? i would suggest a bigger HDTV that would look better. this would be kind of small? perhaps that infamous westy 37" one?
