2. A lot of cardio is the most efficient way to lose body fat. FALSE!
Excessive cardio will strip muscle mass and body fat. This is definitely not the most efficient method for losing body fat. Once you begin stripping muscle mass, your body becomes less efficient at burning body fat. Muscle is metabolically active, which simply means it stimulates the metabolism.
For each pound of muscle you put on, you will burn up to 50 additional calories per day. If you strip muscle mass, all you accomplish is sabotaging your efforts to efficiently reduce body fat.
9. You can put on a lot of muscle and lose a lot of fat at the same time. FALSE!
You can put on muscle and lose some fat in minimal amounts. However, the body functions best when it has one goal at a time. If your goal is to put on a lot of muscle, then make that your number one objective. If your goal is to lose significant body fat, then your focus should be on preserving your much earned muscle mass.
In 2001, prior to starting my training for one of my bodybuilding shows, I weighed 164 pounds (I compete as a bantam or lightweight) at 15.7 percent body fat. In 2003, prior to starting to train for a show this June, my weight was 169.5 pounds at 12.6 percent body fat. As you can see, I put on some muscle and lost some fat. The change was significant but realistic. As I prepare for my show in June, I will attempt to preserve what I?ve earned as I reduce to approximately 3 percent body fat.
Originally posted by: Amused
High impact, high intensity, long duration cardio is counter productive to putting on muscle mass, and can actually cost you muscle mass. If you're looking to bulk up limit the intensity, duration, and impact of your cardio training. In fact, my best strength and muscle mass gains have been made while I was severely limiting my cardio to under 30 minutes, three times a week at under 130 BPM (I'm old, probably 140 for you).
When I lost weight, I gained little mass, but lost a lot of fat. I was running 4-5 miles a day, 4 days a week. When I cut that back, the muscle mass came on much faster.
But don't listen to just me. I learned what I know from the local body builders and instructors at my local gym. It's been verified in a recent post here about "fitness myths."
Look at this from Mr Connecticut:
This is exactly what I've pointed out before. If you want to cut, cut. If you want to put on mass, put on mass, but don;t try doing both at the same time. It's counter productive and will only frustrate you.
Originally posted by: Qosis
from the source himself 🙂 my apologies for misquoting him at one part.
Originally posted by: WinkOsmosis
Hmm.. about being cut or big etc... I'm 5'8" and 135lbs.. or less. I'm in college and you know how that goes. I want to gain mass, so does this mean that I should not do much cardio and do more wieight lifting? I really don't like running... I get stitches, and my knees hurt sometimes 🙁. Also, I'm out of breath after about a quarter mile! So apparently I need to increase stamina and heart strength, but I guess this means I have to do wait until that's improved to put on muscle mass?
Originally posted by: yellowfiero
how much running? how much lifting?
