Hi,
I have a strange issue that I am hoping I could get some help with....
I currently have the following setup:
Asus A8R32-MVP Deluxe 0701 BIOS
Opteron 170
Sapphire Vapor-X 4890 1GB
OCZ 550w PSU
4x512mb Kingston HyperX PC3200 DDR
I just got a hold of 2 1GB sticks of OCZ Platinum PC3200 and tried to replace 2 of my 512mb sticks with these.... and thats when things went downhill!
This issue is that as soon as BOTH of the 1GB sticks are installed together they immediately set the DRAM Frequency to 100MHz regardless of the setting in the BIOS. I have removed all of the 512mb sticks to perform some tests. When either of the 1GB OCZ sticks are installed alone in the mobo they read 200MHz in CPU-Z just fine. However, as soon as I install the second 1GB stick, whether single channel or dual channel, the system will ALWAYS use a DRAM Frequency of 100MHz. I have tried adjusting timings in the BIOS but nothing seems to help. Also, if I try enabling a higher MEMCLK Frequency than 100 MHz in a program like A64 tweaker the system will immediately shut down.
Im not sure if this is an issue with the OCZ Platinum brand and the A8R32-MVP Deluxe motherboard or if all 1GB memory modules will cause this issue?
If it helps, both of the OCZ modules have the P/N OCZ4002048ELDCPE-K on them. However CPU-Z identifies only one of the modules with this part number and the other with OCZ4001024ELPE.
Any help is appreciated!
Opteron 170
OCZ 550w PSU
