Ok, I've got two seti directories under /opt/ (seti1 and seti2). I also renamed the executables so I can tell which is which under top. Now, I've made cron jobs for both of them to run every 4 hours. I had to start each client via command line so I could login under my name and all, and each of them seemed to use one of the CPUs. I was quite happy it was so simple. Now, when I try and run seti2 from cron, I get this error:
Output from command /opt/seti2/seti2 ..
Couldn't get lock file. This is probably because
another instance of SETI@home is running in this directory.
Each instance of SETI@home must run in a separate directory.
Can anybody help me out here? I can't leave ssh up 24/7 to do this. 🙁
