- Feb 28, 2000
- 2,318
- 0
- 0
Was just wanting to know if i run a Hub into my Router to expand my ports,will everything run basically the same,or will the Hub slow down everything?
My Router is the SMC Barricade with built in switch.
The Hub will prob just be a cheapo 10BT.
Will my Routers switch also work on the systems hooked to the Hub?
or should i just go with a switch instead of the Router?
just looking for a cheap way to gain a couple extra ports and keep same bandwith as now.
Thanks for any info.
Shawn.
Shawn.
