Running processor without proper cooling?
Yza
I have a slot-a athlon 500 thats been overclocked since last december to 750 1/2 l2 cache.
Anyways I just noticed bad system crashs like .. it was overheating. this is over a span of a month.. So I check out my heatsink turns out the clips where worn out..
Anyways I got more thermal paste and zip ties holding it together right now, Ordering a new heatsink/fan as we speak.
I was just woundering Do you think I damaged my processor in anyway?
IT seems to be running fine now.
Oh yeah, what do you recommend for a slot-a heatsink/fan combo?
thanks ct
I doubt you ruined your processor. They are pretty hardy.
You can use any PII coolers for your SlotA athlons.
yeah i was worried about system.. damage everything seems to be working A OK!
Just need to order a new heatsink fan combo...
You may have shortened your processor's life somewhat. It depends on how badly overheated it was. Next time, check the processor when your system first crashes.
Or better yet, install a temperature monitoring system (like Motherboard Monitor). If you have any doubts right now about proper CPU temperature, return to default until you get your new HS.
Running a CPU for an extended period (greater than a minute) over its aboslute maximum rated voltage and/or temperature can affect the long-term reliability and can also decrease the frequency overhead of the CPU (overclockability).
I accidentally ran a celeron 300a with 3.0V for about 45 seconds. Proir, it could reach 504MHz at 2.1V. Afterwards, I needed 2.1V just to reach 428.
Eric
ThermalTake's Golden Orb is pretty decent for the slot-A Athlons. I'm using one now, my 650 runs at 850 w/ a GFD and 1.85V.
