Running out of disk space. Replace w/2gb drive? hybrid drive? or SSD?
JEDI
29,391
2,738
I have an old AMD quad core 960T Phenom (3ghz) machine w/4gig ram and a 1tb hd.
I have 177gb left of disk space, and the machine feel sluggish.
I just use it to surf the web, and do some light Word/Excel.
since I'm running out of disk space and Black Friday is coming, should I:
1) replace the 1tb w/a 2tb ($69)
2) replace the 1tb with a hybrid drive ($?)
3) buy a SSD and make the 1tb my D drive for data (what size ssd?)
or..?
Ken g6
Moderator
Dec 11, 1999
16,698
4,660
75
The Crucial MX100 256GB is a really good deal at $100 or so. Looks like it's currently running $110. I'd be surprised if it didn't go on sale again before Black Friday.
monkeydelmagico
3,961
145
there is a crucial 256gb for around $100.- at amazon or a Toshiba 512gb for $200.- at B&H photo. Depending on what you want to spend either would be good
corkyg
Elite Member | Peripherals
27,370
240
Unless your BIOS can provide AHCI, it is not cost effective to get a SSD for that machine. Of course, there will be a slight improvement otherwise, and you can always keep ita and use it when you upgrade your system.
Ken g6
Moderator
Dec 11, 1999
16,698
4,660
75
I completely disagree. I'm using an SSD on a Core 2 Quad that doesn't provide AHCI, but it's still very beneficial.
lehtv
11,897
74
I bet you couldn't even tell the difference between AHCI enabled or disabled unless benchmarking.
pauldun170
9,497
5,713
or..?
You have 1TB drive and still have a space 177gb on it. It shouldn't feel sluggish just because of that.
A fresh install and a cleaning up of your data would probably spruce things up.
A SSD as a system drive and that 1TB being used for a data drive would rock your world
Charlie98
6,298
64
Couldn't have said it better.
I put a little 120GB M500 in my daughter's old (2007) Dell AMD dual-core laptop, and with a fresh install of W7 it's like a new computer.
JackMDS
29,552
429
I have the same experience on with few Core 2 Quad and AMD x955.
The improvement of running the main drive with the OS and main app on SSD is very pronounced.
That said there is point.
The old system would not use the whole power/speed of a state of the art SATA III.
One option is to buy an older less expensive SSD SATA II. Personally I opt not to save the $20-30 difference and buy a good SSD (like mentioned above). Doing so leaves me with a good SSD to use later on in Better upgraded system.
:cool:
