- May 1, 2001
- 3,004
- 3
- 81
Hi All. Right now I am trying to run Prime95 & 3Dmark 2001SE Demo Loop w/ Audio; simultaneously as a ?burn-in? for my new CPU overclock. I tried to run both earlier and it was okay, until I wanted to exit out of the 3Dmark Demo. But now I have a few questions.
1. When I ended the 3Dmark Demo, I get a SUMOUT error in Prime95. I suspect this happens due to me exiting the 3Dmark Demo, and not because of a CPU problem, does this sound right. I also get a 3Dmark error message, but I would expect that if I hit the ESC key during the demo.
2. When running the Demo & Prime 95; for the Demo what is the resolution I should have it run at. In the beginning I had it run at 1280X1024, but this would always lock up. So now I just go with the default option of 640X480.
3. Finally, do you know what the keyboard command, if any, would it be for the 3Dmark2001SE Demo so I can just exit out of the demo,; without causing Prime95 to stop. Or is ESC the only way to exit the Demo loop?
Thanks a lot if anyone can get back to me ASAP, as by the time you do I will be running the 3Dmark2001SE Demo Loop & Prime95 for at least 24 hours. If you could suggest anything else, please let me know. But I want to run it over the long haul with the right settings, AND know how to get out of the 3Dmark demo.
Thanks to anyone for suggestions/tips
BTW: as it is now I am testing with FSB 270 Vcore 1.525 Vdimm2.7 AGP Voltage 1.50V CAS 2-3-2-5. RAM is running at 216.3Mhz.
