As many others on these forums, I'm awaiting the nForce4 mobos to come out, so I can get it and slap on a winchester and overclock my hearts out.
But I have one unanswered question while figuring out my system setup. In my current AXP setup I have some 2x 512MB Geil PC3200 Ultra Dual Channel memory. I can't decide whether its a good choice to keep this memory in my upcoming setup.
My goal will be to reach 2.5-2.6GHz, with either the winchester 3000+ or the 3200+. I'm trying to figure out which memory divider I will have to run to reach these CPU speeds. I haven't pushed this memory yet (my A7N8X-Deluxe doesn't like high FSBs), but judging by reviews I found on the web it seems like this memory will do around 225Mhz (450DDR) with its speced 2-6-3-3 timings.
So what would be my best choice? Aim for 250-260FSB with memory (divider) set to 166 in bios (which should make the mem run just above spec) coupled with the 3200+ which has a 10x multiplier to reach my target speed, or should I get the cheaper 3000+ with a 9x multiplier and aim for FSB 280-290MHz, with memory set to 133 in bios? In the later case I think my memory would run a little below spec?
So basically wondering if I can save a lot of cash and keep my current memory, and if so, should I put up some extra cash to get the 10x multiplier of the 3200+ instead of 9x with the 3000+. I'm also very curious about how the asyncronous memory settings suggested above would affect my overall system performance... Would I get a big hit in performance if I ended up with async memory running running a bit below 400MHz?
