Running Lifemapper on XP Ramdrive
GeorgeCredland
Recently came across this site offering free Windows XP Ramdrive
software...
http://www.arsoft-online.de/
I couldn't get it working above 64MB (increased tracks to 4), but it
is still enough to run Lifemapper in.
Handy if you run 24/7 and don't want to wear the HD out.
(Renewable Energy contract, so no worries about the environment)
Enjoy.
George
Lifemapper
Thanks for the link...
To be totally honest, most DC apps don't talk to the hard drive that much. Also, running a harddrive 24/7, without it turning on/off is actually better for the drive, as it's life is measured in cycles, rather than x hours. Also, when running it from a RAMdrive, if you lose power for whatever reason, then any work you've done is lost. You can set it to save the state of the drive to the HDD every now and then, but then it will be defeating the purpose of a RAMdrive in this case, which is to try to reduce the work done by the hdd. This has been discussed many times in the past, and it is generally felt that there is no point in running from a RAMdrive, as if you lose power, you've lost much more work than you may gain by running it from a ramdrive!
Welcome to the forums, by the way 🙂 I hope you enjoy your stay, and join in in lots of discussions 🙂
Edit: Oh yeah, most people here run their systems 24/7 anyway, so there's no need to preach about not worrying about saving energy here! Just to those zealots in GH or OT! 😉
Garry
Lifemapper workunits only take around 15mins and the UPS gives up to 10mins
coverage. The worst that could happen is around 15mins lost work.
George
