Running higher resolution
supster
26
I was just reinstalling WinXP and after the initial reboot I was changing the resolution from defualt 800x600 (this was before display driver update) and noticed that I could take the slider one bar past the normal 1600x1200 I run.
After installing the latest nvidia drivers I was back down to 1600x1200 ax my max, is there anyway I can get access back to that greater resolution??
StraightPipe
1,676
usually there is a button to "show screen sizes that are not supported"
something like
display properties/settings/advanced...
jim1976
2,704
I wouldn't advice you to switch back to an unsupported resolution. You might fall into darkness!!!
