Running games and something not right.... snowflakes. Need help
ren16
15
I was just playing Max Payne and for some reason the screen has white dots flickeing. Can anyone tell me what to do?
And also, can anyone tell me what the best drivers for the ultra out right now are?
billyjak
Need more info, video card, processor, ram etc.
Did you install the Max Payne patch yet.
MichaelD
31,528
"Snow" usually means either your videocard is overclocked too high or is overheating. I'd go with the WHQL 12.41 drivers. They aren't the latest ones, but are well-known to be "a really good set".
Are you OCing your card? If so, set it to stock speeds. If not OCing, check to make sure that the fan on the vidcard hasn't died. Not out of the ordinary for this to happen.
I know nothing about the patch for the game. Sheesh, didn't the game just hit the stores a few days ago? They have a patch already? THat's a good thing, though!
ren16
15
I'm sure its not max payne cuz it happened to a test in 3dmark 2001
Geforce2 Ultra
P3 1000mhz
386mb ram
where can i find those drivers?
Xray
Snow like dots on the screen is a sure sign of overclocking your ram to high on you vid card.
Are you doing that? If not sounds like you might try getting some more air on you vid card.
ren16
15
I dont need the patch, just need to fix my snow problem. and also, over all i feel my comp isnt running its full potenial(sp?). I got 2947 on my 3dmark2001 test but some tests i got like 13 fps. help tweek my comp please
