running Firefox and IE
Phillip
72
any idea.....what effect this would have on the computer?
would it slow things down a lot?
firefox is my browser of choice, but IE is better for a couple of specific apps....
Sam25
1,722
29
I mainly use IE for banks and ticketing purposes. Rest of it is with FF. Doesn't seem to slow down my PC though, then again I don't run many tabs at the same time on FF.
Phillip
72
hmm i usually use different windows for firefox....just tabs when a link opens it up....
is there a diff in performance between FF windows and tabs... ?
MrChad
13,507
The IETab extension will let you run Internet Explorer windows within Firefox for sites you choose.
corkyg
Elite Member | Peripherals
27,370
239
an interesting question. I decided to put it to the test. On my system with XP-Pr0/SP3, it works OK. This screen shot shows FF and IE8 both open at the same web page getting the same info.
FF-IE
I just can't think of a rational reason to do it - but it can be done. :)
Adam8281
2,181
doesn't slow down the computer - I use them both all the time, + Chrome
