Running engine for short time w/o serpentine belt - okay?
ThisIsMatt
Banned
Aug 4, 2000
11,820
I wouldn't be hurting anything by running a dodge v8 w/o the serpentine belt on for a few minutes, would I? Obviously heat is a concern, since the water pump will be disconnected, but I'm only talking a few minutes. Any other concerns?
notfred
38,241
4
for 2 or 3 minutes it will be fine. the water pump is the only thing to worry about, keep an eye on the temp guage.
ThisIsMatt
Banned
Aug 4, 2000
11,820
The water pump is actually the thing I want to check out...something is making an abnormal amount of noise, and a mechanic figured it was the water pump because it has some play in it, but he wasn't certain...
desertdweller
588
You'll be fine until it heats up.
Alot of the newer trucks have problems with the tensioners making noise
in the 5.2L and 5.9L.
DD
ThisIsMatt
Banned
Aug 4, 2000
11,820
DD
It's a 92 (93?) B250 V8
desertdweller
588
DD
Those I rarely did any work on, sorry. One thing you can do to find the noise is
to take a long, long prybar or screwdriver and run the motor. Put it against
various parts of where you think the noise is coming from and put the handle
to your ear. You can hear whats going on in the bearings that way.
I'd probably do that before I took the serp belt off.
DD
Wingznut
16,968
If your mechanic cannot figure out what accessory is making noise, then it's time to find a new mechanic.
Follow desertdweller's advice about the long screwdriver/prybar... But be VERY CAREFUL working around the rotating pullys and fan. Especially on a B van where you don't have a lot of room.
ThisIsMatt
Banned
Aug 4, 2000
11,820
Yeah, I said "a mechanic" not "my/our mechanic" ;) It was when I took the van in to get smogged, the guy had some concern about it. The fan & pully wiggle around a bit, so I think he's probably right. Our normal mechanic (a really good shade tree mechanic, very honest and trustworthy) just moved out of the county a few months ago :(
Wingznut
16,968
Ah, I see. :)
Most likely, he is correct that the water pump is to blame. If I were a betting man, I'd put money on it.
<-- (Ex) Dodge Mechanic of 10+ years. :)
speed01
1,167
If your water pump pulley has play in it I would go with it being the problem. There should not be any play in it. You should have it replaced as soon as you can because you don't want it coming apart on you. I've had that happen once and it wasn't pretty, took out the radiator, transmission cooler lines, one side of the exhaust and beat the hell out of the underside of the hood bad enough to dent it from the inside.
Speed
desertdweller
588
Ah, I see. :)
:) I did 4 years at a Dodge dealer. Honda before that and now I'm in the wonderful world
of IT.
DD
Wingznut
16,968
Ah, I see. :)
of IT.
Beats the hell out of being a flat-rate mechanic, huh? ;)
Regarding the "play" in the pulley... Look at it carefully... The movement you see could be the fan clutch being wobbly. It still would warrent replacement, but it is very unlikely that it could be making the noise. Also, a worn fan clutch can cause a water pump bearing to go out.
