Thanks to all your help here I orderd 2 x 144 opti's based on the info from anandtech articles and from info here in the forms.
"You know you can run 2 1XX chips. Unless AMD has changed them, which I doubt, the 1XX series chips are the same as the 2XX chips.
So get a couple OEM 144's and run them.
Anandtech's article talked about the 1XX, 2XX, and 8XX all being the same right NOW. But in the future they will probable lock them out."
WELL THE FUTURE HAS COME UPON US! I installed the pair and the system would not even video out. I remove one of the processors and it works. Just to be parinoid I also ordered a pair of 240's and everything works great. The version of 144's that i recived ended with "AJ". I used the MSI Master 2 FAR MOBO with the VIA K8 chipset.
