running Defrag while running antivirus scan...is it OK?
tooltime
1,029
is it ok to run a defrag while running a program like an antivirus scan at the same time? and why?
i don't think it's a good idea
...thx
xtknight
12,974
No, because the defrag program will be locking and moving files around and the antivirus may not be able to scan it. Speed will severely decrease as well.
bruceb
8,874
111
It is always best to run either Antivirus or a Defrag with nothing else
running except what your computer boots up with ... and of course,
if you think you have any viruses, you should run AV in Safe Mode
so it can get rid of them
TheRyuu
5,479
14
No. One or the other.
I always just set a defrag going when I go to bed. That way in the morning it's done. Same thing with a virus scan.
