If the Av program has a file open, the defrag will skip it. If the defrag program is moving a file when the Av program tries to scan it, the AV program will skip it.
Should not be a problem if the defragmenter has half a brain and intelligently uses free system resources to defrag. It will give priority to the AV scan and then automatically suspend/resume defragging according to AV's resource consumption. A good automatic defragmenter will do this. If you are running a scheduled defrag, it may bog down the system though, as both programs are resource intensive and compete for resources.
Which actually reminds me, it's time I updated my XP rig to AVG Free 8.0 🙂
