- Dec 6, 1999
- 10,575
- 292
- 126
I'll be running a non-o/c dual machine which will be doing intense cpu work. If it weren't for the intense work, I wouldn't be wondering if I should bet a better than factory HSF that came with CPUs (xp2000 or x2100). But I know that with SMP sometimes it's better to have more overhead in the cpu, and better cooling might provide that.
Question is, will the retails fans still be good enough under mostly intense cpu work in an SMP setup?*
* if you think I need after market hsf, pls recommend one. Thanks
EDIT: I guess I should ask, in case an aftermarket hsf IS needed, how many degrees that would drop it, cuz I can't see spending the money if it's not at Least 9 or 10c drop (preferably more).
Thanks
Thanks
