Trying to help someone out here. They already have a single coax in each of the rooms. they want to add cat5/6 to the same plate. I know there are leviton, etc. plates that have the blank hole for various connections. Are there any inserts or whatever they're called for coax?
If so, how is the coax cable connected inside? Do I need a special tool of some sort to disconnect it from the current one and connect it to a new one?
Any other advice on this is appreciated.
