Running BOINC Headless
ichy
What's the easiest way to run BOINC on a computer that doesn't have a hard drive? When I upgraded my current computer I was left with an old motherboard, processor, RAM and video card that have just been sitting around. I wanted to connect them to my network and use them to run BOINC, but I've had some trouble finding a guide on how to set it up.
No idea, but I have a feeling one of the frequenters here can tell you. If there isn't a way or it is too involved what about a small HDD?
Yep. That's how people run "SETI farms" where they have a bunch of really barebones systems doing nothing but number-crunching. I think you have to have one computer that has a hard drive and Windows or Linux in order to run everything. What I'm trying to do is find a simple way to run such a setup at home.
Yes, you can run boinc or any other application from a USB stick Pendrive distribution of Linux, like Ubuntu, Knoppix, DSL, MiniMe, Slax... (you can use pendrive from 64MB and up)
The distro creates a Ramdisk and uses it as a harddrive, REMEMBER: all WUs and data will be lost when you shut down your computer! (If you still want to do it, make sure you install boinc on the USB stick.)
This is was I need. 🙂
