Originally posted by: the cobbler
don't use them. connect directly to the PSU. the motherboard has enough things going on without having to route voltage to a bunch of fans imho.
Originally posted by: GalvanizedYankee
You must look at the spec provided by your mainboard provider.
My ASUS is 8W for the CPU HS fan header. 8W/12V=.666A and I have no need for that powerful a fan.
...Galvanized
Are you going to be putting this 120mm@32W beauty on your HS?? 😛
http://www.sidewindercomputers.com/de12gf.html
...Galvanized
Originally posted by: Howard
Some fans come with both a 4-pin Molex and a 3-pin mobo header. When both are plugged in, does the 4-pin share the draw?
